REKLAMASWM RS 650 R#1 17.06.2017 18:49:43
SWM RS 650 Rzajímá mě tohle moto, má to někdo? jaké jsou recenze? je vhodný jako adventure bike? dá se na něm dojet relativně pohodlně na UA či do Bosny a tam pak pěkně prohnat v terénu? Váha i výkon OK, nádrž 12 L, dělá se i větší, jaké jsou možnosti dalších úprav, kapotáže atd? GENERAL FEATURES WHEELBASEmm1.510 OVERAL LENGHTmm2.260 OVERAL WIDTHmm820 OVERAL HEIGHTmm1.240 SADDLE HEIGHTmm910 MING GROUND CLEARANCEmm270 TRAILmm115 KERB WEIGHT WITHOUT FUELkg144 FUEL THANK CAPACITYlt12 ENGINE OILlt1.8 HOMOLOGATIONEURO 3 & EURO 4 ENGINE CHARACTERISTICSSINGLE CILINDER 4 STROKE BOREmm100 STROKEmm76,5 DISPLACEMENTcm³600 COMPRESSION RATIO12,4:1 MAX POWERkW 40 / (23 DEPOTENZIATA) COOLINGBY LIQUID WITH 2 WATER RADIATOR + ELECTRIC FAN STARTINGELECTRIC WITH DECOMPRESSOR TIMING SYSTEMDOHC 4 VALVE LUBRIFICATIONWET SUMP WITH LOBE OIL PUMP AND CARTRIDGE FILTER IGNITIONELECTRONIC INDUCTIVE DISCHARGE WITH ADJUSTABLE ADVANCE DIGITALSPARK PLUG TYPE“NGK” CR 8EB FUEL SYSTEMELECTRONIC INJECTION FEEDTHROTTLE BODYMIKUNI Ø 45 CLUTCHWET, MULTIPLATE TYPE WITH HYDRAULIC CONTROLL.DRIVING DISC8DRIVEN DISC7 PRIMARY DRIVEENGINE SPROCKETZ 32CLUTCH GEARZ 75TRANSMISSION RATIO2.344 TRASMISSIONCONSTANT MESH GEAR TYPESPEED GEARS N°6 INTERNAL RATIOS1st2,6152nd1.8123rd1.3504th1.0915th0,9576th0,880 SECONDARY DRIVETRASMISSION SPROCKETZ 15REAR WHEEL SPROCKETZ 42TRANSMISSION RATIO2.800 DRIVING CHAINREGINA ORC6 (5/8 x 1/4) CHASSIS FRAMEHIGH STRENGHT STEEL ROUND PIPES, SINGLE BEAM DOUBLE CRADLE MAIN FRAME, REAR FRAME IN LIGHT ALLOY FRONT SUSPENSION“FAST ACE”UPSIDE DOWN TELESCOPIC HYDRAULIC FORK WITH ADVANCED AXLE, REBOUND DAMPING ADJUSTMENTØ FORK LEGSmm 43TRAVEL ON LEGS AXISmm 219 REAR SUSPENSION“SACHS”PROGRESSIVE “SOFT DAMP” TYPE WITH SINGLE HYDRAULIC SHOCK ABSORBER, SPRING PRELOAD ADJUSTMENT, COMPRESSION AND REBOUND DAMPING ADJUSTMENTWHEEL TRAVELmm 270 FRONT BRAKEFIXED DISC WITH HYDRAULIC CONTROL AND FLOATING CALIPERØ DISCmm 300 REAR BRAKEFIXED DISC TYPE, WITH HYDRAULIC CONTROL AND FLOATING CALIPERØ DISCmm 220 FRONT RIM1.60 x 21” REAR RIM2.15 x 18” FRONT TIRE90 / 90 x 21” REAR TIRE140 / 80 x 18” ELECTRICAL EQUIPMENTVOLTAGE12 VBATTERY12V - 6Ah Editoval offroaderTE (17.06.2017 18:50:56) Jezdím-padám-vstávám...pokud ještě můžu :-) offline #2 18.06.2017 01:04:26
Re: SWM RS 650 RoffroaderTE: Nezadržujte prdy, ty pak přechází po páteři do mozku a odtud vychází posrané nápady! offline #3 18.06.2017 07:54:20
Re: SWM RS 650 RNa Motosalonu jsem byl ty zde opevovane SWM okouknout. Priznam se ze jen kvuli tomu, protoze zde na foru o teto znovu-obnovene znacce byly napsany "ody na radost" od mnoha zdejsich clenu. offline #4 18.06.2017 11:16:45
Re: SWM RS 650 Rkick-start: A vis kdo vlastni KTM? Bez tech "zlutasku", jak o nich pises, by uz davno byla firma ko offline #5 18.06.2017 15:12:01
Re: SWM RS 650 RV pátek odpoledne jsem ji poprvé viděl na silnici. Jeli ve dvou a ještě nějaké bádly. Ze silnice do terénu a zase zpátky. offline #6 18.06.2017 18:36:37
Re: SWM RS 650 RSWM ma ted nove superdual t a x, jeden s 19/17 koly a druhy s 21/ 18. To i rs vychazi z te630, což je tusim-li spravne rok 2012, zadny 80 leta. A ze by nekdo z japoncu udelal neco podobneho to zatim nevypada, takze muzeme byt radi za to. me osobně vadi jen maly zdvih na prednim kole, offline #7 18.06.2017 18:37:08
Re: SWM RS 650 RSWM ma ted nove superdual t a x, jeden s 19/17 koly a druhy s 21/ 18. To i rs vychazi z te630, což je tusim-li spravne rok 2012, zadny 80 leta. A ze by nekdo z japoncu udelal neco podobneho to zatim nevypada, takze muzeme byt radi za to. me osobně vadi jen maly zdvih na prednim kole, offline #8 19.06.2017 00:30:02
Re: SWM RS 650 RNemyslim si, že design je z asie, jak je vidět na mnoha i evropských pokusech, ne každý je designové eso aa třeba KTM dělá design externě u věhlasného studia, což stojí asi slušné lowe a ne každý to je ochotný dát. Nezadržujte prdy, ty pak přechází po páteři do mozku a odtud vychází posrané nápady! offline #9 19.06.2017 00:36:08
Re: SWM RS 650 R..jo - nechtěl jsem kritizovat, ale se neudržim - chtěl jsem vidět na motosalonu 650 R, i kdyby to byla pos*aná olítaná zablácená EURO III vytažená z pangejtu, ale na stánku bylo tušim jedno malý endurko a prd prd cililink, to ty prodeje budou panečku padat samy... Nezadržujte prdy, ty pak přechází po páteři do mozku a odtud vychází posrané nápady! offline #10 19.06.2017 05:59:49
Re: SWM RS 650 RStanďour: Je to barva, kterou mám prostě rád Modrá je dobrá, už je to tak. offline #11 19.06.2017 07:24:21
Re: SWM RS 650 RStoreman: offline #12 19.06.2017 09:30:56
Re: SWM RS 650 RStanďour: z prezentace SWM cca 14 zpět. Fotky obou verzí už mají na stránkách ,jen ve specifikaci jsou zatím jen popisy pro T verzi ,tedy tu cestovnější. Pro T630 to má jiný podeslový rám ,který by měl mít větší nosnost a menší zdvihy odpružení, 260 vzadu a 210 v předu, mohli v předu nechat taky 260 ,ať to něco pobere. Editoval Kome (19.06.2017 09:34:02) offline #13 19.06.2017 09:55:25
Re: SWM RS 650 RHrozna splacanina. Skoro boli se na tu motorku podivat offline #14 19.06.2017 15:07:43
Re: SWM RS 650 RTa cast sedla pro ridice je standart nebo to je nejaka snizena uprava pro hobity? Enduro - I love this game:-) KTM - Klub Týraných Mužů offline #15 19.06.2017 16:58:40
Re: SWM RS 650 RJanek: top modelka, ale se stejným motorem a kromě podvozku asi horšími díly a je skoro za dvojnásobnou cenu offline #16 19.06.2017 17:01:00
Re: SWM RS 650 Rkick-start: kolik dalších nových cestovních endur okolo 600ccm má podobnou cenu a váhu? Rád bych si koupil 600ccm, stříkačku, váha okolo 160kg a nejlépe Yamaha, může být i Honda offline #17 19.06.2017 17:36:37
Re: SWM RS 650 RPalo7: offline #18 19.06.2017 20:12:49
Re: SWM RS 650 RJanek: já to nekoupím, ani AJP nevěřím ani jedněm. Ale kdyby to SWM mělo motor Rotax, Minarelli apod. tak bych o tom vážně uvažoval. offline #19 19.06.2017 21:21:01
Re: SWM RS 650 RMě se na tom líbí to, že je to tak nějak kompletní! Editoval Storeman (19.06.2017 21:23:03) Ze silnice do terénu a zase zpátky. offline #20 20.06.2017 07:08:41
Re: SWM RS 650 RNa m.cz je vlakno s dotazem na AJP PR7, cituji: offline |
