SWM RS 650 R
#1 17.06.2017 18:49:43
Motorka: GG EC 250 TPi
SWM RS 650 R
zajímá mě tohle moto, má to někdo? jaké jsou recenze? je vhodný jako adventure bike? dá se na něm dojet relativně pohodlně na UA či do Bosny a tam pak pěkně prohnat v terénu? Váha i výkon OK, nádrž 12 L, dělá se i větší, jaké jsou možnosti dalších úprav, kapotáže atd?
obstojí ve srovnání s KTM 690 a HQ 701 ???
https://www.youtube.com/watch?v=-ZzAAF6SsMY
http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/1994_581c5b2b62dd2492160072.jpg
GENERAL FEATURES
WHEELBASEmm1.510
OVERAL LENGHTmm2.260
OVERAL WIDTHmm820
OVERAL HEIGHTmm1.240
SADDLE HEIGHTmm910
MING GROUND CLEARANCEmm270
TRAILmm115
KERB WEIGHT WITHOUT FUELkg144
FUEL THANK CAPACITYlt12
ENGINE OILlt1.8
HOMOLOGATIONEURO 3 & EURO 4
ENGINE
CHARACTERISTICSSINGLE CILINDER 4 STROKE
BOREmm100
STROKEmm76,5
DISPLACEMENTcm³600
COMPRESSION RATIO12,4:1
MAX POWERkW 40 / (23 DEPOTENZIATA)
COOLINGBY LIQUID WITH 2 WATER RADIATOR + ELECTRIC FAN
STARTINGELECTRIC WITH DECOMPRESSOR
TIMING SYSTEMDOHC 4 VALVE
LUBRIFICATIONWET SUMP WITH LOBE OIL PUMP AND CARTRIDGE FILTER
IGNITIONELECTRONIC INDUCTIVE DISCHARGE WITH ADJUSTABLE ADVANCE DIGITALSPARK PLUG TYPE“NGK” CR 8EB
FUEL SYSTEMELECTRONIC INJECTION FEEDTHROTTLE BODYMIKUNI Ø 45
CLUTCHWET, MULTIPLATE TYPE WITH HYDRAULIC CONTROLL.DRIVING DISC8DRIVEN DISC7
PRIMARY DRIVEENGINE SPROCKETZ 32CLUTCH GEARZ 75TRANSMISSION RATIO2.344
TRASMISSIONCONSTANT MESH GEAR TYPESPEED GEARS N°6
INTERNAL RATIOS1st2,6152nd1.8123rd1.3504th1.0915th0,9576th0,880
SECONDARY DRIVETRASMISSION SPROCKETZ 15REAR WHEEL SPROCKETZ 42TRANSMISSION RATIO2.800
DRIVING CHAINREGINA ORC6 (5/8 x 1/4)
CHASSIS
FRAMEHIGH STRENGHT STEEL ROUND PIPES, SINGLE BEAM DOUBLE CRADLE MAIN FRAME, REAR FRAME IN LIGHT ALLOY
FRONT SUSPENSION“FAST ACE”UPSIDE DOWN TELESCOPIC HYDRAULIC FORK WITH ADVANCED AXLE, REBOUND DAMPING ADJUSTMENTØ FORK LEGSmm 43TRAVEL ON LEGS AXISmm 219
REAR SUSPENSION“SACHS”PROGRESSIVE “SOFT DAMP” TYPE WITH SINGLE HYDRAULIC SHOCK ABSORBER, SPRING PRELOAD ADJUSTMENT, COMPRESSION AND REBOUND DAMPING ADJUSTMENTWHEEL TRAVELmm 270
FRONT BRAKEFIXED DISC WITH HYDRAULIC CONTROL AND FLOATING CALIPERØ DISCmm 300
REAR BRAKEFIXED DISC TYPE, WITH HYDRAULIC CONTROL AND FLOATING CALIPERØ DISCmm 220
FRONT RIM1.60 x 21”
REAR RIM2.15 x 18”
FRONT TIRE90 / 90 x 21”
REAR TIRE140 / 80 x 18”
ELECTRICAL EQUIPMENTVOLTAGE12 VBATTERY12V - 6Ah
Editoval offroaderTE (17.06.2017 18:50:56)
#2 18.06.2017 01:04:26
Stanďour
Motorka: LC4, ex XT600Z
Tel: komurkowy
Re: SWM RS 650 R
offroaderTE:
Na jaře na motosalonu ještě hlásili, že se čeká na Euro IV. Na druhou stranu AJP ji už má. Jinak co se týká propagace u nás, tak  ne  Zrovna tahle mě taky přijde zajímavá.
#3 18.06.2017 07:54:20
Re: SWM RS 650 R
Na Motosalonu jsem byl ty zde opevovane SWM okouknout. Priznam se ze jen kvuli tomu, protoze zde na foru o teto znovu-obnovene znacce byly napsany "ody na radost" od mnoha zdejsich clenu.
Po te co jsem na vlastni bulvy spatril vystavene SWM jsem se nejak nemohl srovnat s tim co jsem se o nich do te doby docetl zde na foru. Celkove se mi ty motorky totiz vubec nelibily. Nekdo prevlekl do radoby moderniho vzhledu motorky ze 70-80let. Zbrkle a bez radneho odzkouseni. Je na nich hodne videt ze zpracovani je radne odflaknute. Kdybych nemel odsud z fora nacteno jake jsou to znovuvychazejici temer superstroje, rekl bych si dalsi cina a presel tuhle znacku bez povsimnuti.
Pri odchodu ze stanku ma dorazil detail, objem petistovky je 501ccm a kvuli tomu jednomu nadbytecnemu ccm je zakonne pojisteni temer dvojnasobne. Uz tady je videt ze nekdo opravdu premyslel.
Nechtel jsem kazit radost obdivovatelum techto stroju co zde pisi jak do nektere SWM pujdou az prodaji tu co maji momentalne v garazi, ale muj zaver byl po zheldnuti na vlastni bulvy jasny - SWM nikdy.
Proc to ale zde pisu. Pred par dny jsem narazil ma m.cz na clanek kde je napsano ze SWM vlastni nekdo z asie. Uz se nepanatuji zda je to Cina, Indie Taiwan, ci jina zluta narodnost. A tehdy me docvaklo, proc jsem se nemohl srovnat s tim ze Italska motorka vypada takhle hnusne. On totiz jeji deign navrhoval zluty konstrukter co slezl z Royal Einfeldu, licencne dosud vyrabene kyvacky ci jineho old school motocyklu. Zkouknul par modernich, odzkousenych endur Japonske a evropske produkce a konal. Vysledek se dostavil. Italske jmeno vlastnene "cinou" a tomu odpovidajici vzhled a hlavne technicka uroven motorek. Ale aby v tom nebyla SWM sama tak Benelli potkalo neco podobneho a dalsi staro-nove znacky budou jiste tenhle trend nasledovat.
V techto firmach nejde o to vzkrisit pohaslou tradici jak se docitame z jejich reklamnich materialu, delat vyvoj, nasazovat tovarni teamy do zavodu jako to delaji Ducati, KTM a Japonci. Jde o to na jmenu vice ci mene slavne znacky kratkodobe vyprodukovat zisk a az se trh nasyti tak sbohem. Koupime neco jineho, lyze, zahradni techniku, rehabilitacni pomucky, .... atd.
#4 18.06.2017 11:16:45
Re: SWM RS 650 R
kick-start: A vis kdo vlastni KTM? Bez tech "zlutasku", jak o nich pises, by uz davno byla firma ko
Presto jezdi MS v mnoha segmentech motosportu
#5 18.06.2017 15:12:01
Storeman
Místo: Týn nad Vltavou
Tel: 728173269
Re: SWM RS 650 R
V pátek odpoledne jsem ji poprvé viděl na silnici. Jeli ve dvou a ještě nějaké bádly.
Na recenzi někoho, kdo ji opravdu vlastní jsem také zvědavý.  wink
Recenze někoho, kdo ji viděl na výstavě, vlastně neviděl, protože tak 650-tka nebyla.. a  hned poznal že je vyrobená "zbrkle a bez řádného odzkoušení...odfláknutý...???" nejsem zvědavý!
a ty "ody na radost" jsou psány na to, že někdo takovou to motorku vůbec začal vyrábět a že je v přijatelné cenové relaci! O kvalitě a výdrži samozřejmě nikdo nic neví, když je to úplně nové!
#6 18.06.2017 18:36:37
Re: SWM RS 650 R
SWM ma ted nove superdual t a x, jeden s 19/17 koly a druhy s 21/ 18.  To i rs vychazi z te630, což je tusim-li spravne rok 2012, zadny 80 leta. A ze by nekdo z japoncu udelal neco podobneho to zatim nevypada, takze muzeme byt radi za to. me osobně vadi jen maly zdvih na prednim kole,
#7 18.06.2017 18:37:08
Re: SWM RS 650 R
#8 19.06.2017 00:30:02
Stanďour
Tel: komurkowy
Re: SWM RS 650 R
Nemyslim si, že design je z asie, jak je vidět na mnoha i evropských pokusech, ne každý je designové eso aa třeba KTM dělá design externě u věhlasného studia, což stojí asi slušné lowe a ne každý to je ochotný dát.
Na druhou stranu - bez přehánění - co předvádí čínští soudruzi v oblasti technologického pokroku u osobních aut (kdo viděl reportáž z autosalonu v šangaji ví), tak asi budem za pár let tady všichni v evropě čumět ...
#9 19.06.2017 00:36:08
Stanďour
Tel: komurkowy
Re: SWM RS 650 R
..jo - nechtěl jsem kritizovat, ale se neudržim - chtěl jsem vidět na motosalonu 650 R, i kdyby to byla pos*aná olítaná zablácená EURO III vytažená z pangejtu, ale na stánku bylo tušim jedno malý endurko a prd prd cililink, to ty prodeje budou panečku padat samy...
Kome - kdes viděl typy superdual T a X?
#10 19.06.2017 05:59:49
MotoDriver
Místo: Mechov
Motorka: 250f
Věk: 40 a víc
Re: SWM RS 650 R
Stanďour:
Tady jso obě.
Píše se o tom ve světě.
http://overdrive.in/news/details-of-swm … -to-india/
Modrá je dobrá, už je to tak.
#11 19.06.2017 07:24:21
Re: SWM RS 650 R
Storeman:
Na motosalonu byli vystavene 300, 500 a nejaky garazovy nedodelek ve stylu retro. 650 tam samozrejme nebyla, takze se omlouvam ze jsem to napsal do tohoto vlakna. Nasel jsem ze je tu jeste jedno o SWM, asi to melo skoncit v nem.
Nepsal jsem ale zadnou "recenzi", nehodnotil jak to jezdi. Jen jsem zkouknul ty dve motorky na vystave, vzpomel si jake chvaly jsem se na ne docetl a zhrozil jsem se jak skutecne vypadaji v realu.
At si kazdy koupi za svoje penize co se mu libi. Me se SWM, po te co jsem je videl v realu nelibi, takze si je urcite nekoupim. To uz se mi vice libila AJP PR5 nez ty dve tam vystavene.
RS 650R ma celkem nadupany motor. Je to 600ccm, 40kw, kompresni pomer 12.4:1 Predpokladam ze tam bude predepsana castejsi vymena oleje nez cestovatelskych 6000km.
Kdyby ta motorka mela radovy dvouvalec 500-600ccm ktery na trhu porad chybi, nebo jednovalcovy 450ccm s cestovnim limitem servisnich intervalu tak pochopim ze je o ni zajem. Ale prijit s jednovalcovym 600ccm, kterych uz bylo vyrobeno v ruzny modifikacich tri prdele, je podle me krok vedle.
Dvouvalcovou 500-600ccm a umravnenou 450ccm s cestovnimy servisnimy intervaly dosud nikdo nevyrabi, takze neni kde kopirovat. Vymyslet neco nove? kdeze? proc? Jednobuchu 600ccm je zkonstruovano dost, staci si vybrat ktery se zkopiruje.
#12 19.06.2017 09:30:56
Re: SWM RS 650 R
Stanďour: z prezentace SWM cca 14 zpět. Fotky obou verzí už mají na stránkách ,jen ve specifikaci jsou zatím jen popisy pro T verzi ,tedy tu cestovnější. Pro T630 to má jiný podeslový rám ,který by měl  mít větší nosnost a menší zdvihy odpružení, 260 vzadu a 210 v předu, mohli v předu nechat taky 260 ,ať to něco pobere.
http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/5980_swm_superdual_x_01.jpg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/5980_swm_superdual_x_02.jpg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/5980_swm_superdual_x_03.jpg
Editoval Kome (19.06.2017 09:34:02)
#13 19.06.2017 09:55:25
Re: SWM RS 650 R
Hrozna splacanina. Skoro boli se na tu motorku podivat  hmm
PR7 je proti tomu top modelka
Zas kdyz se bude libit miliardam cinanu, indu, pakystancu, .....proc ne.
#14 19.06.2017 15:07:43
ZbyneKTM
Motorka: KTM EXC 525, Honda VTR 1000
Tel: můj?:-)
Re: SWM RS 650 R
Ta cast sedla pro ridice je standart nebo to je nejaka snizena uprava pro hobity?
Vypada to docela "zádržně" a nehejbave ou2
Enduro - I love this game:-)
KTM - Klub Týraných Mužůsmile
#15 19.06.2017 16:58:40
Palo7
Místo: Hustopeče
Motorka: KTM 690 Enduro
Věk: 41
4 1
Re: SWM RS 650 R
Janek: top modelka, ale se stejným motorem a kromě podvozku asi horšími díly a je skoro za dvojnásobnou cenu  a31
#16 19.06.2017 17:01:00
Palo7
Místo: Hustopeče
Věk: 41
4 1
Re: SWM RS 650 R
kick-start: kolik dalších nových cestovních endur okolo 600ccm má podobnou cenu a váhu? Rád bych si koupil 600ccm, stříkačku, váha okolo 160kg a nejlépe Yamaha, může být i Honda
#17 19.06.2017 17:36:37
Re: SWM RS 650 R
Palo7:
Hrozne moc lidi to chce, ale nikdo z vas si to nekoupi  lol  lol
Stary bawo 650 Dakar vypada oproti tomu o 10 let mladsi a nejaky kila jsou v tyhle kategorii zanedbatelny kriterium.
No nic, basnete o tom dal. Chte nechte tady 100% souhlasim se startpakou  ano
#18 19.06.2017 20:12:49
Palo7
Místo: Hustopeče
Věk: 41
4 1
Re: SWM RS 650 R
Janek: já to nekoupím, ani AJP nevěřím ani jedněm. Ale kdyby to SWM mělo motor Rotax, Minarelli apod. tak bych o tom vážně uvažoval.
#19 19.06.2017 21:21:01
Storeman
Tel: 728173269
Re: SWM RS 650 R
Mě se na tom líbí to, že je to tak nějak kompletní!
Má to hlavní a boční stojan, padáky, rám na kufr, plexi...a hlavně pořád přijatelná cena.
...a protože jsem o tomto typu motorky zauvažoval ... a na novou nemám... v pátek jsem přivezl BMW F650 GS Dakar (2004) ...
...a je vymalováno!  ano  cool
Akorát mám obavy, aby se s Frýrajdrem v garáži nepokousaly  lol
Editoval Storeman (19.06.2017 21:23:03)
#20 20.06.2017 07:08:41
Re: SWM RS 650 R
Na m.cz je vlakno s dotazem na AJP PR7, cituji:
Dotaz 4: bude enduro neRallye verze bez štítu a tabletu za nějakou rozumnější cenu, blížící se SWM R650RS? (Cca 180tis)
Odpoved od Streetmoto, cituji:  Verze R v produkci nebude, hlavním důvodem je i spolupráce s SWM a použítím motoru...Jelikož PR7 je opravdu "rally" motorka a SWM žádnou takovou v produkci nemají,uvolnili motor pro AJP.
Nejak nechapu jak Italska firma SWM "uvolni" svuj motor pro naprosto cizi Portugalskou firmu AJP. U softvare mi to jasna je, kdyz neko uvolni zdrojovy kod programu, znamena to ze kazdy kdo to umi tam muze cokoliv doprogramovat, zdarma pouzivat, jen ten SW nesmi prodavat dal. napr. Linux
Co znamena pojem "uvolnit motor"? To jako ze jedna firma druhe - konkurencni, poskytla plany na vyrobu jejich motoru?
Podle to co je napsano v tom vlakne na m.cz ma AJP PR7 stejny motor jako SWM RS650. Jopr tu motorku ma, muze sem napsat jake servisni intervaly mu predepisuje vyrobce v manualu. Staci vetily a olej.
