Cestování (114)
Srazy (69)
Výlety (109)
brzdové destičky
#21 07.04.2017 13:44:16
bobkuuu
Místo: 6 km od hraníc ČR Lysá, Púchov
Motorka: 690
Tel: +421904249455
1 1
Re: brzdové destičky
Musíš to zosúladiť s kotúčmi nech nedere nakoniec tie a platničky ostanú nové   lol
#22 10.04.2017 17:33:03
Rischwon
Motorka: WR250R/X, EXC250
Tak sem se díval přes víkend na doklad od těch desek,..a dle všeho mi tam dal Goldfren S33,..
#23 29.07.2017 18:56:15
zetkarider
Místo: Prešov- Slovensko
Motorka: yamaha yz250f
Takže obloženia delta braking po jednom tréningu na motokrosovej trati cca 1.6 mth.  Zadné
http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3562_received_1386996101379009.jpeg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3562_received_1386996054712347.jpeg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3562_received_1386996044712348.jpeg
Editoval zetkarider (29.07.2017 18:56:36)
BORSUK enduro team
#24 29.07.2017 21:54:49
zetkarider: mám podobnou zkušenost. Hovno vydrží.
#25 30.07.2017 08:31:19
zetkarider:
Podľa popisu na webe majú byť LONG LASTING  usch  Tá D-éčková zmes bude asi trvácnejšia...
N-compound. DELTA braking standard compound.
High friction. No fading. Long lasting. Not aggressive towards the disc. A classical compound in sintered metal friction technology.
The N(2) compound has obtained a TÜV Approval.
D-compound. DELTA braking heavy duty compound.
Where others give up: D goes on! Special in use under extreme circumstances: mud, sand, water. Therefore in use in off-road and quads. High friction, No fading. Extreme long lasting. But more aggressive towards discs!
CPRO-compound. A new development by DELTA braking R&D
A soft compound containing a high percentage of, specially developed, friction carbon. Extreme high friction. Very high temperature resistant. In use for (semi) road-racing, supermotard, and motocross, but … pay attention: CPRO, being a soft compound, doesn’t like the combination of mud, sand, and water!
http://s26.postimg.org/xh3usvkm1/ktm.png
#26 30.07.2017 19:42:55
zetkarider
kiwibibo:
Long lasting😂😂😂
Ak by neboli long... Tak na jeden pretek potrebuješ potom 3pary, trening, 1. Rozjazd 2. Rozjazd
Tak ma ešte napadlo či to nemôže byť dajaka polska replika alebo niečo take...
BORSUK enduro team
#27 31.07.2017 06:45:56
WoxmenRX
Motorka: Červená 350
Podobná zkušenost. Po jednou enduro víkendu na PEHu jsem je měl taky na plech  a1 Jezdím DP brakes SDP. Jsou super a neubejvaj před očima jako Delta.
#28 31.07.2017 19:06:20
zetkarider:
Je to blízko Poľska, Ostrava smile
#29 16.04.2018 07:01:23
Super desky Brembo, 4 mth a zničený nový kotouč.
http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3313_20180415_094436.jpg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3313_20180415_094406.jpg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3313_20180415_094339.jpg
#30 16.04.2018 09:02:17
chalka:
Kotouc jaky origo?cislo tech desek?at vim cenu se vyhnout..
Diky
#31 16.04.2018 09:07:37
rc28
Motorka: WR450F 05
chalka: Máš nějaký vyzkoušený kotouč a desky dopředu? Taky mě to čeká a zatím nejlepší reference mají oboje DP brakes. Neměl jsi na Yamaze origo plovoucí kotouč? Teď máš normální, pociťuješ nějaký rozdíl?  Btw jedeš na offroadmaraton do Jihlavy? Díky
#32 16.04.2018 13:05:49
rc28: Koupil jsem moto s origo kotoučem a deskama APracinng, co prodává jeden zdejší člen v yacomi.
Kotouč jsem ohnul a dal nějaký noname, ale brzdí to parádně. Teď mají přes 70 mth a je tam ještě cca 1/3 - 1/2 masa. DP mi tolik nikdy nevydržely, ale jsou to taky výborný desky poměr/cena ano Ty AP jsou dražší, ale nekoukal jsem, jestli nejsou třeba jinde za míň.
https://www.yacomi.cz/kategorie/motocyk … 00/?page=2
Chalka, označení těch destiček nemáš?
Brembo je v tomhle špička ano
Offroad směs, pokud nemáš závadu na brzdách, nemůžeš takhle sjet za 4 mth i když budeš jezdit jako mistr světa.  nee1
Mě se to stalo na zadku po 100 a něco km při použití desek se směsí pro silniční moto.
Editoval Janek (16.04.2018 13:06:26)
#33 16.04.2018 14:12:31
Oznaceni desek v popisku, jezdim vyrabeny kotouce, jsou silny a s original nissin deskama brzdi paradne a vydrzi hromadu rán.
rc28: mezi plovoucim a pevnym jsem nespozoroval rozdil. Ano ted uz mi bylo doporuceno dat na novy kotouc tvrde desky DP. A Pistovsky mokrady nejedu, prej se u nas v ten termin jedou lepsi zavody  usch
Fotky oznaceni desek a rozdil v sirce mezi oroginalem a vyrabenym.
http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3313_received_10214147039303179.jpeg http://www.offmoto.com/domains/offmoto.com/uploads/thumbs/3313_20170103_194314.jpg
Editoval chalka (16.04.2018 14:24:11)
#34 16.04.2018 14:44:29
Samozřejmě když nevidíš motorku těžko něco soudit, ale dovolím si říct, že rozhodně museli desky odejít kvůli nějakému tech. problému. Není možné, aby si je standardně ojel za 4mth.(pokud jsi tedy nejel neustále v nějakém extra bahně).
Tom
#35 16.04.2018 15:31:02
Marýlek
Motorka: KTM 200 EXC
Věk: 20 a vic
Hele ja sem mel ted na predku delta braking na zkousku. No a taky neco okolo 4mth a byly fuc. Kamos je jezdi a najede na nic nesrovnatelne vic. Takze nejspis si nesedly s kotoucem nebo nevim.
#36 16.04.2018 20:29:03
chalka:
Podle te destrukce.....jednoznacne to asi muselo pribrzdovat neustale za jizdy...to jsi nepozoroval?.(mohl by zato i ta silnejsi tloustka kotouce)
Takhle me driv skolili (silnejsi) desky od Goldfrenu...
Věřím že na vrchol nevedou zkratky, jen krev, pot a slzy !
#37 16.04.2018 20:35:06
No hlavne paleny kotouc neni ethalon,tam se neni ceho chytit,to je jen vykrik do tmy,navic se mohlo fakt neco pos.... Nerikam ze musi byt spatny ale ja jsem na slusny jeste stesti nemel a zkouset uz to nebudu.
#38 16.04.2018 21:38:27
Hoždy jitrnice :D
Motorka: Kachna
Věk: 30 +
Tel: s pavoukem
Nasadil jsem Delta Braking na pohár Lysé hory, po cca 2 hodinách zadek pryč a zničenej kotouč na kole hmm Předek dojel tak s 1mm. Nasranej jsem s tím jebl a koupil origo - nesmrtelná záležitost.
#39 16.04.2018 23:12:40
Nemá cenu platit 1000Kč za originál - doporučuju desky DP Brakes jsou taky sinterovaný a kupuju je za 500Kč. Výdrž super, brzdí super - takže všechno richtig!  ano
Hodně dobrý reference jsou z Ameriky, tam jsou hodně populární - https://www.facebook.com/dpbrakesracing/
#40 18.04.2018 07:22:11
WoxmenRX
Jezdím DP Brakes MX Pro v kombinaci s páleným kotoučem. Odjel jsem s touto kombinací celou závodní sezónu + něco v tomto roce pak jsem je vyměnil, ale furt měly tak 2-3mm. Jednou jsem si dal Delty a také mi shořely za jeden enduro víkend cca 4-5mth. Musím ale říct že to bylo schopný zaflekovat na místě  lol
