Cestování (120)
Srazy (70)
TM 300
#101 30.07.2014 15:12:41
Re: TM 300
badyšot:
Mě to vyšlo na 700 i s poštou z Francie. Je to udělaný z nějakýho plastu. Tak zkus někoho, kdo by to udělal? Myslím si, že by to nemusel být problém. Koukal jsem na Gase a ten to má taky.
#102 30.07.2014 16:40:33
Re: TM 300
Myslím, že by nebyl problém to za pár kaček vyřezat na laseru.
#103 02.09.2014 22:43:22
MotoDriver
Místo: Mechov
Motorka: 250f
Věk: 40 a víc
Re: TM 300
chalka:
Dám to s dovolením k tobě,týká se to TMky všeobecně.
Novinky u TM Racing pro rok 2015. ano
what's new for the 2015 TM models:
MOTORCYCLES UPDATES MY 2015
ENGINES 2STROKE
85 2T MX
- carburetor Keihin φ 28mm.
125 2T MX/END
- exhaust valve steel cables modified for extended life
- optimized mapping of exhaust valve ECU
- longer conrod
- high tech crankshaft bearings and oil seals
- cylinder ports modified for higher performance and smoother power delivery
- expansion chamber and silencer modified for higher performance and smoother power delivery
144 2T MX/END
- exhaust valve command lever modified for extended life
- exhaust valve steel cables modified for extended life !!
250/300 2T MX/END
- cylinder with electronic exhaust valve
- cylinder head
- crankshaft
- transmission cover, clutch cover and water pump lighter and more compact
- gearbox sensor for better exhaust valve response according to the selected gear ratio
CHASSIS 2STROKE
85 2T MX
- graphics 2015
125/144/250/300 2T MX/END
- modified chassis geometry
- rear suspension link geometry modified to optimize the progression
- rear shock lenght increased by 8mm.
- rear shock setting suited to new progression
- rear wheel axle diameter increased from 22mm. to 25mm.
- fully renewed style thanks to complete set of plastics and seat with trendy and aggressive design
- fresh air flow system towards the airbox by an air intake on fuel tank and apposite pipeline
- graphics 2015
ENGINES 4STROKE
250 4T MX/END
- inlet duct, throttle body and air funnel modified to improve engine feed
- bigger oil suction filter
- exhaust system modified for higher performance and smoother power delivery
- gearbox sensor to optimize the engine ECU map according to the selected gear ratio
450 4T MX/END/SMR/SMM/SMX
250/450 4T MX/END
- shortened chassis and modified front fork rake
- longer swing arm to increase weight distribution
- bike layout fully revolutioned to increase engine feed and weight distribution by moving the
fuel tank under the seat and the airbox over the engine
- front fork tripleclamps with reduced offset to improve rideability in combination with new
fork rake
- improved air filter for better efficency
design
- graphics 2015
450 4T SMR/SMM/SMX
design
- graphics 2015
- front brake caliper monoblock billet by DP (optional)       ano
450ka bude mít nádrž pod sedlem ano ,sem zvědavej kde bude nalívací hrdlo.
Pár fotek 450ky fi
http://www.vitalmx.com/forums/Moto-Rela … TM,1267243
Ještě je pár fotek detaílů,ty dodám později.
Modrá je dobrá, už je to tak.
#104 13.09.2014 12:34:10
SethX
Místo: Dubné
Motorka: KTM950ADV, KX250 89', YZ250
Re: TM 300
Zdar, jdu sem pro rady, malinko pošilhávám po tejhle TM 300
http://motorky.bazos.cz/inzerat/3879975 … X-2007.php
Mám YZ 250 02 a chtěl bych omladit park  smile  Láká mě na ní hodně ten podvozek.  Jak je to u TM s dostupností a cenama dílů? Nebo je nějakej důvod proč se TM vyhnout?
#105 13.09.2014 13:41:50
19 6
Re: TM 300
SethX:
Konkrétně tohle TM hodně koluje po netu a mění majitele.... těžko říct proč, i mě se ho tehdá snažil bazarník vnutit výměnou  a1
#106 13.09.2014 14:53:15
Re: TM 300
má to tm ubec přívěru???
#107 13.09.2014 15:25:35
Re: TM 300
SethX:
ten podvozek není nic moc, původně pochází od kamaráda. Někdo se v tom šťoural a předek je měkkej, proto se toho zbavoval. Jinak já proti TM nemůžu říct nic negativního. Jsem s ní nesmírně spokojenej, slouží už 100 mth a paráda. Jinak ji mám na netu, objevil jsem jednu 2011 a po té slintám.
http://www.tipmoto.com/motorky/tm/268538-en-300.html
S dílama absolutně žádný problém, většinou vše skladem. A ceny přijatelné. Něco je "levné" něco dražší. Ale za originalitu to stojí!
Stáhneš si rozkres motorky, ceník a mrkneš...
moto-enduro.sumperk.net/
mcf.cz
jimird: jasně že má...
#108 13.09.2014 17:47:09
SethX
Místo: Dubné
Re: TM 300
chalka:
Dík za info, takže nic pro tlustocha jako já  a1  Jestli je to takováhle putovní tak to asi jen tvrdší pružiny nespraví a nebo je na ní ještě nějakej problem. Škoda. Ta 2011 je hodně pěkná, ale já to chci jen na MX a na to moje šudlání je to moc peněz  usch
#109 13.09.2014 18:08:04
Re: TM 300
SethX:
né, já bych ji nebral, od něj už to má asi 5tý majitel. Takže s ní asi něco bude big_smile
http://www.motoinzerce.cz/motorky/tm/824953-mx-300.html
takhle se nepáčí?
#110 13.09.2014 18:20:03
SethX
Místo: Dubné
Re: TM 300
chalka:
Na tu sem se taky koukal, ale na tej první se mi právě líbila Ohlins vidle a o 10 nižší cena.
#111 13.09.2014 21:22:24
Grinder
Místo: Chebsko
Motorka: KTM 250 EXC
Re: TM 300
To víčko nádrže bude asi z boku . http://www.lorenorace.it/tm-moto-modell … iche-foto/
Editoval Grinder (13.09.2014 21:24:59)
#112 14.09.2014 10:26:33
Re: TM 300
Grinder:
jak tak koukám, tak u těch 2T 300 tam rvou zase elektroniku. RC přívěru a jakejsi snímač rychlosti. Tohle nechápu.....
#113 14.09.2014 20:43:28
sykator
Motorka: Honda 450 CRF, KTM 250 EXC
Re: TM 300
peTTR napsal(a):
SethX:
Jo tu prodává kámoš smile  smile  Prostě je to peklostroj a není jednoduchý jí ukoučovat
#114 20.09.2014 22:41:25
Full Throttle
Motorka: KTM 500 EXC-F
Re: TM 300
chalka napsal(a):
Dneska jsem se zajímavosti po cca. 50 mth vydělal podložku klapek a zkusil to projet bez ní. Okamžitě šla zpět. Motorka ztratila spodek a déle trvalo, než se roztočí ze spodních otáček.
http://rawmotorsports.net/index.php?id_ … er=product
To je jen rada pro ostatní, co se spodkem bojují. Není to nic extremního, ale znát to opravdu je. Podložka se instaluje mezi klapky a domeček sání. Má 4mm plus 1mm těsnění. Schálně by mě zajímalo, kdyby to někdo zkusil na jiné motorce, třeba i na nižším obsahu. Vyrobit si myslím, že by to nebyl problém.
To co popisuješ je hlavní rozdíl mezi klapkama VFORCE3 a VFORCE4 , takže to funguje  ano
http://www.offmoto.com/uploads/thumbs/4396_fot67c9.jpg
#115 11.10.2014 23:33:15
MotoDriver
Místo: Mechov
Motorka: 250f
Věk: 40 a víc
Re: TM 300
TM pro rok 2015-125ka a 250ka
od této fotky: https://www.facebook.com/tmracingnederl … =3&theater
po foto 19 a fotky 30,31,32,36
https://www.facebook.com/media/set/?set … 737&type=3
https://www.facebook.com/25720036434157 … =1&theater
E: odkaz
Editoval MotoDriver (11.10.2014 23:36:51)
#116 12.10.2014 09:28:03
Re: TM 300
MotoDriver:
to je luxusní zpracování, zajímalo by mě, jestli je ta RC přívěra v něčem lepší. Třeba jde líp nastavovat?
#117 24.10.2014 06:56:50
MotoDriver
Místo: Mechov
Motorka: 250f
Věk: 40 a víc
Re: TM 300
Další foto detailů TM 2015  heart  ano
4 T
https://www.facebook.com/tmracingnederl … =1&theater
2 T
posouvání fotek je v pravo nahoře těsně nad foto
U 2 T je vidět v detailu ten senzor zařazené rychlosti,kterej má spolupracovat s elektronikou a řídit přívěru,tak jsem zvědavej,jak to bude fungovat-spolehlivost,možnosti nastavení přívěry.
Ještě mě udivilo,že tam dali VForce3,když sou k dispozici 4ky.
U 4 T je dobrý to hrdlo nádrže z boku pod sedlem,snad to bude lepší než zhora.
Editoval MotoDriver (24.10.2014 06:59:55)
#118 24.10.2014 09:28:40
19 6
Re: TM 300
Eletronická přívěra není ve světě žádnou novinkou, takže pokud ji udělají pořádně bude fungovat spolehlivě. Čidlo zařazené rychlosti je principiálně taky uplně jednoduchá věc tam se nemá co posrat a spoustu ostrejch endur už to má taky spoustu let.... Takže bych se zrovna tady těch dvou el. fičurek nebál.... ikdyž jsem u přívěry zastáncem mechaniky  ano
#119 24.10.2014 09:50:46
carbous
Motorka: Kawasaki kdx 250, Gas-Gas ec 300, KTM exc 450 2012
Věk: 39
0 2
Re: TM 300
Elektronicky ovládané přívěry měli už japonské 2T dávno. Např Honda CRM 250, Suzuki TS 200 atd. Tam to nebylo závislé na zařazené rychlosti, ale na množství proudu které produkovalo zapalování podle otáček motoru. Fungovalo to bezvadně a nebyl tam ten skok jako u odstředivky. Nevýhoda byla že krokový motorek co tahal za lanka měl vnitřek komplet z plastu a pokud přívěra zatuhla ve válci dost často se stávalo že se olámali zoubky na soukolí. Dalo se to ale uvnitř otočit a použít tak druhou stranu (chodilo to jen kousek). Je to má zkušenost, obě tyto motorky jsme měli doma a na svou dobu to byli hodně dobré stroje. Měl jsem i KDX 250 a ta měla přívěru mechanickou je byl rozdíl oproti KX že měla jen dvě otočné po stranách a nebyla tam ta středová jako u KX (myslím verzi SR) Rková verze měla válec z KX 250.
#120 24.10.2014 11:18:43
MikiberG
Motorka: HusaberG
Re: TM 300
Ve zkratce - brání pulzaci směsi a s tím souvisejícím negativním projevům..
... u 2T s překrývajícími sacími a přefukovými kanály to kladně ovlivňuje průběh motoru
